tecnovist Posted November 7, 2007 Share Posted November 7, 2007 Hi I am interested to find out about a PSA - Pressure Swing Absorption ---Oxygen Generator the ones for Generateing Oxygen for use in a small engineering shops ----gas welding of panil steel mostly for oxy-acetelyne welding all thow having enouth for Oxy propane cutting--- Would be a good thing to have ---I am interested in the cost of a P.S.A to do that type of work ---IF any one knows the Prices of these things that would be neet ---- Thank you for you time---- Quote Link to comment Share on other sites More sharing options...
Glenn Posted November 7, 2007 Share Posted November 7, 2007 From Wikipedia: Pressure Swing Adsorption (PSA) is a technology used to separate some gas species from a mixture of gases under pressure according to the species' molecular characteristics and affinity for an adsorbent material. It operates at near-ambient temperatures and so differs from cryogenic distillation techniques of gas separation. Special adsorptive materials (e.g., zeolites) are used as a molecular sieve, preferentially adsorbing the target gas species at high pressure. The process then swings to low pressure to desorb the adsorbent material. Using two adsorbent vessels allows near-continuous production of the target gas. It also permits so-called pressure equalisation, where the gas leaving the vessel being depressured is used to partially pressurise the second vessel. This results in significant energy savings, and is common industrial practice. Applications of the PSA technology One of the primary applications of PSA is in the removal of carbon dioxide (CO2) as the final step in the large-scale commercial synthesis of hydrogen (H2) for use in oil refineries and in the production of ammonia (NH3). Another application of PSA is the separation of carbon dioxide from biogas to increase the methane (CH4) content. Through PSA the biogas can be upgraded to a quality similar to natural gas. Research is currently underway for PSA to capture CO2 in large quantities from coal-fired power plants prior to geosequestration, in order to reduce greenhouse gas production from these plants.[1] PSA is an economic choice for small-scale production of reasonable purity oxygen or nitrogen from air. PSA technology has a major use in the medical industry to produce oxygen, particularly in remote or inaccessible parts of the world where bulk cryogenic or compressed cylinder storage are not possible.Chemistry in New Zealand; Vol 55, No 2, 1991Universal Industrial Gases8000 Nm3/hr total liquid production (Approximately 300 tons per day)Praxair A little internet research may yield better information on what your are seeking. Quote Link to comment Share on other sites More sharing options...
KevinD Posted November 7, 2007 Share Posted November 7, 2007 Maybe you can find one at a yard sale or a flea market... J/K I had no idea how much "man" has been manipulating "nature" till I started researching oxy/gas welding. Quote Link to comment Share on other sites More sharing options...
tecnovist Posted November 7, 2007 Author Share Posted November 7, 2007 Glenn Hi and Thank you for that info most interesting I understood it worked the same way a diver gets the bends ... the nitrogen in the blood boils when it is depressurized to fast the diver then has a gas in there blood and the Oxygen boiled later or at a lower pressuer ---but that's just me nutting it out --- himm wonder what the Absorption material is Zorbox marketed a small plant --but thet no longer doing it Quote Link to comment Share on other sites More sharing options...
habu68 Posted November 7, 2007 Share Posted November 7, 2007 I have a oxy unit that followed me home from the dump. it is the type used for home health care. It will produce 5 cu/L/min at about 5 lbs pressure. I have used it to supply a small oxy/map syystem (hand held). worked well. take care with the tubing that is used for health care around fire. It will burn like the fuse in a Pirate movie. It is hard to out run it to the machine. Don't ask me how I Know. ;-) Quote Link to comment Share on other sites More sharing options...
Candidquality Posted November 7, 2007 Share Posted November 7, 2007 Sounds interesting, though i'm not sure if buying a machine would be cheaper than getting it from a local supply. I could see it if you're off in the outback. Just like electricity, hard to beat on-grid prices. If it was cheaper it would be common I'd think. Only on a rare occasion do you find something that useful not already being used. Hijack: anyone here ever seen some of the old acetylene generators that were marketed to blacksmiths? Why are they not used anymore? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 7, 2007 Share Posted November 7, 2007 Because they went BOOM! all the time! Just tell your insurance agent that you plan to install one and if he has a clue he'll cancel your policy so fast the paper will be smoking! Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted November 7, 2007 Share Posted November 7, 2007 its hard to get the 14nd calcium carbide anymore, and then there is the problem of getting rid of the by product of acetylene generation. Quote Link to comment Share on other sites More sharing options...
pyroguy_3 Posted November 8, 2007 Share Posted November 8, 2007 A couple labs in the chemistry dept. at Ill St. U. (where I go) have Nitrogen generators of this type. All I know is that those are very far from cheap... Basically it pressurizes air, and then picks out the Nitrogen using various membranes/crystal lattice type things. Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted November 8, 2007 Share Posted November 8, 2007 My wife is on an oxygen concentrator 24/7, given to us by Woody after his wife passe, the biggest ones put out 5 liters but the oxy content is around 91% at that flow, New ones run from the cheap $5 rand ones on up. Quote Link to comment Share on other sites More sharing options...
Mark Parkinson Posted November 8, 2007 Share Posted November 8, 2007 Lampworkers and glass blowers use oxy cons insted of tanked gas heres a link to one site tht sells them pyronamix home I have more site if you need more info. the used (reconditioned)ones are a much better deal if you do not need it for medical use a new medical use unit is $5500 the same unit for lampwork is $550 Mark Quote Link to comment Share on other sites More sharing options...
tecnovist Posted November 8, 2007 Author Share Posted November 8, 2007 well thanks for that info it starting to look like thay maybe way to much exspence ----we could once owned the gas Ac&Ox bottals -but not any more we have to hire then $25 for the 2 bottals ,a month plus the cost of Gas ------ some one eles said that PSA only put out 95% Oxygen -- and that was not pure enouth for oxy-acetelyne welding -- is that cerrect?? Mark Parkinson---Hi--- hay thanks for the link and if you could Please ---put up the other links up--- i will go for a look see--- Quote Link to comment Share on other sites More sharing options...
hooligan971 Posted November 8, 2007 Share Posted November 8, 2007 My cousin was looking into this on a larger scale before he passed away. He ordered a couple books ,and if I can find them you are welcome to have them. I believe he ordered them from Lindsay publications.Any of you who don't get this catalog are missing out. I must have a hundred of his books and will be ordering more. Can't get this stuff anywhere else. Quote Link to comment Share on other sites More sharing options...
MJ Hofbauer Posted November 8, 2007 Share Posted November 8, 2007 I had seen this posted locally a few weeks ago (Might still be available) Don't know if this is what you are looking for, granted you are slightly too far for local pickup, but maybe the model info will help. And perhaps someone else on the forum would be interested in this one. Nuvo Mark 5 Oxygen Concentrator -MJ Quote Link to comment Share on other sites More sharing options...
jim frank Posted November 14, 2007 Share Posted November 14, 2007 I have a used home medical version as well. It works just fine to make my propane torch a lot hotter, but with 5 LPM at maybe 3-4 psi, it has nowhere near enough capacity for any kind of cutting. I got it for free at a yard sale, so who can complain? :) Quote Link to comment Share on other sites More sharing options...
Feromat Posted October 17, 2009 Share Posted October 17, 2009 5LPM oxygen concentrator is good for homecare. If you need the real flow (20LPM and above) you need an oxygen generator. Oxywise has very feasible prices!!! Quote Link to comment Share on other sites More sharing options...
