Posted
I am new here, but thought I would share this...
I rarely like to just buy something to try something out and as you all know a 2 x 72 belt grinder is not inexpensive. I watched a million videos and came across a guy from Canada that developed some plans for a grinder built from wood. If you search 2 x 72 belt grinder on youtube you will find him. I purchased his plans and directed them to modify to my own taste. His plans utilized MDF for all the wheels and I wanted a little more precision from mine so I purchased a drive wheel and tension wheel from Beaumont Metal Works. My wheels for the flat platen are longboard skateboard wheels. Since I had to buy four I made a second attachment for a slack belt. I got a decent 1 HP motor from a friend running three step pulleys and added a switch and a rolling cart under it. The photos here are of it raw wood. once it gets above 15 degrees in my shop I will paint it with a decent paint to prevent movement and hopefully "fire" proof it. Having used it for a little bit, I will say it is smooth as silk and sturdy, but having said that if the bug really bites me I will be getting a KMG. I only have about $350 into this one including an assortment of belts, so it doesn't owe me much. I would be happy to share any information and get detailed photos for anyone who is interested.
WP_20150213_003_zps525zwoig.jpg temporary_zps30eab809.jpgtemporary_zps6c38abc8.jpgtemporary_zpsefc64f19.jpg
Posted
Beautiful work.
With the showers of sparks coming off any steel being ground, I wonder how long the wooden parts will last?  I have set a few shirts and pants on fire!!  You might adhere some thin sheet metal to the wooden table parts at least.
Posted
Beautiful work.
It will probably be short lived as I work out the kinks, I will probably move toward an Aluminum frame as the design works out, but yes, my thought was to make some "mud flaps" so to speak to curtail; any unwanted flames. I have also set a few shirts on fire.
That looks mighty fine! As my signature states... find a way or make one!
Thank you Sir!
Posted
Nice. I like the skate board wheels. Looks like they work fine. I couldn't find an inexpensive 2" wide idler wheel when I made my wood 2x72 grinder and so I made may own.
Posted
​My idler and drive wheels are about 3" wide. Only the platen wheels are 2" wide.
