A collection of improvised anvils
  • Replies 644
Thanks, Frosty!
Charles - lots of great content on Anvilfire, are you referring to the article on slab anvils? I've started grinding a radius similar to the left example in that article. I'm also going to try welding on a little horn horn similar to the middle example.
I'm sorry to hear that it's creator has passed! It sounds like one of his friends has stepped in to keep the information posted so it should remain available as long as he's around to foot the bill. Maybe someone could get permission to convert all of those articles into a book, it would be excellent content to have handy offline!
Kim Thomas pointed out to me this great little hardy tool for larger curves on pages 42-43 of Werk und Werkzeug des Kunstschmieds (The Smithy’s Craft and Tools) by Otto Schmirler:
Here’s my version, welded up from a piece of bent plate and a scrap of angle iron:
It works great.
I've always called it a "ski jump" it's one of the tools I was planning to demo for the NMABA. Mine was made from a torch cut piece of 1.5"? plate I found at the scrapyard.  It had both the gentle and more abrupt sides.
I also picked up a copy of the book at a smith's estate sale; I have it right next to "Geschmiedetes Eisen" by Kuhn and "Damaszener Stahl" by Sachse.  (Another German book I like is "Schöne alte Wirtshausschilder"  by Leonhard.)
I start the initial curve on shoes simply by bracing the tongs against my leg supporting on end of the bar wile the other end is supported on the anvil. Rounding hammer applied to the middle to start the curve.
closing the 90 is easy enough by placing one end on the anvil face and striking the other end wile griping the center with tongs. The branches for front shoes can be bent buy placing the toe on the anvil and striking the end (heal) rear shoes are not as easy but doable by bending the shoe so one can access the heal.
the same tricks have been used for mallinia,
  • 1 month later...
You might try drilling and bolting through the wood; those metal extensions would snag me if it was working in my shop. (With London pattern anvils; I have the stand clamping bolts under the horn and heel so I will hit the anvil before I run into them...)
My first "constructed" anvil stand was made from rough sawn oak that had been the floor of a horse trailer. The scrapyard gave it to me free.  The best pieces are a set of shelves in my shop.  The intermediate pieces I cut for anvil stands. Then I noticed I needed only 1 more stand to have all my using anvils on stands.  So I made a stand from a heavily cribbed board----seams to have worked ok even if ugly!  (Years later I needed a taller stand for students over 2 meters tall and made one from softwood scraps.  Works too.)
One thing with forging: when moving with hot steel folks often pay more attention to the hot steel than to where their feet and legs are; hence the suggestion to avoid trip and snag hazards when possible.  (How many of us have managed to ram the tip of an anvil horn with our leg---if we were lucky!)
Sorry for the quote. Can't find the blank text on my phone.
I get what you mean. But I know it will work out. I used to work at a shipyard. Awerness for the surrounding has become second nature. Working with a torch cutting steel above your head does that, espacially with collegues doing the same around you
At this moment. I have more problems finding a good spot for everything. A gasforge gives a lot of heat in front of it.
Edited by Mod30
Remove quote
Glenn means you can reply to a post without quoting it by using the text window directly below it. Posts directly following another and on the same subject don't need a quote to know who you are responding to. If it's a few posts down the thread simply addressing the person you're responding to by name works.
Make sense?
